Push notifications to Dynatrace Mobile App
emiliano
Inactive
Hi all!
do you know what IP o port Dynatrace Cluster Management has communication to mission control to push notificacions towards Dynatrace App Mobile?
In order to set the firewall...
Thanks in advance
3 REPLIES 3
skrystosik
Here is all you need:
https://www.dynatrace.com/support/help/shortlink/m...
Regards, Sebastian
emiliano
Inactive
I configured this address, but I do not receive notifications in my app mobile. Maybe, I need other open ports....
It is not only one address but couple of them (ip as well).
I’m not sure if you are familiar with the way how push notifications are working. You have to now that your cluster isn’t sending notifications to your phone by himself. Dynatrace has central server that is authorized in apple and google that can ask to send push notifications. This server is receiving requests from your manage cluster through this communication channel.
Regards, Sebastian
