How to calculate storage size required for 30 days SaaS Purepath data storage ?
rohit_sharma
Guide
We need to find out how we can calculate the right amount of storage size required for 30 days of our purepath data. Is there any matrix/formula for the same ? We currently have 10 days of data retention for service level data.
skrystosik
I think you should use this table from managed version: https://www.dynatrace.com/support/help/deploy-dyna...
But storage for purepaths does not mean only amount of transactions or user actions but as well size of purepaths. On some enviornments they have only couple of nodes, on others hundreds of nodes. If you have 10 days data retention with known storage size you can try to extend it according to this what you have. I'm actually not totally sure how looks options for storage extension on SaaS version 🙂
Regards, Sebastian
Thanks for the details here Sebastian 🙂
