how to Get number of satisfied, frustrated and tolerating user actions for specific time period in dynatrace managed?
ramakrishnan_p-
Organizer
Steps to Get number of satisfied, frustrated and tolerating user actions for specific time period in dynatrace managed?
skrystosik
You should go here:
https://www.dynatrace.com/support/help/monitor/use...
Using USQL syntax should help you extract informations you need.
Regards, Sebastian
