question
Radu S. avatar image
Radu S. asked ·
How does alerting on custom plugin metrics work?
Hello.
In a situation where an ActiveGate plugin is needed to collect metrics from a device which can't run the OneAgent, how would the alerting setup look like?
Let's take a specific example... I have an ActiveGate plugin that runs a remote command on a device and reads back a 1 or 0 based on healthy/unhealthy. What is the recommended way to setup an alert so that I get a Problem opened if the plugin reads a 0? (e.g. would I have to create a Custom Device to store this data, then create a custom alert and find the device in the Host scope? or will my plugin show up under plugin events to configure anomaly detection? or is there a way to set this plugin's data as an indication of availability monitoring for this custom device?!)
Let me know if I'm not being clear enough :)
Thanks in advance!
Radu
configurationDynatrace Managedalertingdynatrace saasextensionsactivegate
1 Answer
Piotr M. avatar image
Piotr M. answered ·
Radu,
please take a look of this help page:
https://www.dynatrace.com/support/help/extend-dyna...
it describes how to push events from AG Plugins. That should help you solve problem.
Peter
1 comment Share
Many thanks Piotr, this answers my question!
0 Likes 0 · ·
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services custom event alerts notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions session replay diagnostic tools permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
