SaaS and Managed Synth HTTP Monitor fails on obsolete security - SSL communication error
imoskovko1
Inactive
Hello
Can one suggest regarding SaaS & Manager HTTP synthetic monitor
In our test env to use RUM/NAM traffic analysis we had to downgrade MS IIS security settings to
Connection - obsolete connection settings
The connection to this site uses TLS 1.2 (a strong protocol), RSA (an obsolete key exchange), and AES_256_GCM (a strong cipher).
In other words, we disabled all Diffie-Hellman key-echange as it was discussed at https://community.dynatrace.com/spaces/160/open-q-a_...
But now Saas and Managed HTTP Synthetic monitor fails on obsolete security connection settings https protocol 😞 - with "SSL communication error".
How to ask HTTP Synthetic monitor to accept MS IIS obsolated security settings-
HTTP v1.1 + TLS v1.2 with all DH disabled (TLS 1.2 RSA AES_256_GCM) ?
Igor
8 REPLIES 8
imoskovko1
Inactive
Here is details. Active gateway is running on CentOS and related Location is defined.
lkoniecki
Dynatrace Helper
Dynatrace Helper
What version of ActiveGate are you using?
All seams to be latest on ActiveGate host:
Installed ActiveGate version: 1.157
Host is monitored. Dynatrace OneAgent is up-to-date on version 1.157
According to support fix is planed for near future ActiveGate release...
Will wait for it.Let know results here.
Thanks to everybody helped with this issue!
Jan_W
Inactive
Hi Igor, please create a support ticket at https://www.dynatrace.com/support/contact-support...
There have been some important updates to the ciphers and security settings supported by HTTP monitors in ActiveGate v159 but it needs to be verified if this particular situation is covered.
Done *****18453
Now in Dynatrace Gateway 1.159.154.20181218-130356
http check is working with MS IIS obsolated security
Case solved. Many thabks!
Dynatrace support is very willing and capable to help! I am impressed. Keep up good job!
picture is here:
