Unable to graph lambda?
tarjei_utnes
Organizer
For some reason I am unable to graph the AWS Lambdas. I see them in the AWS dashboard, I see them in the metric api, but I am not able to create a dashboard with them?
3 REPLIES 3
skrystosik
According to this article:
https://www.dynatrace.com/news/blog/deploying-your...
you should see lambda as process and service. So from both perspective should be possible to create dashboards.
Regards, Sebastian
tarjei_utnes
Organizer
Yep, should be possible. But:
Even though the lambdas are here:
They are not here:
pablo_rocafort2
Newcomer
It is available on version 1.60.
SaaS 1.60 released on Jan 10
Managed 1.60 to be released within the next 3 weeks
