• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
        • Enterprise Synthetic Monitoring
      • Synthetic Classic
        • Synthetic Classic Open Q&A
      • BSM Open Q&A
  • Home /
  • Public Forums /
  • Dynatrace /
  • Dynatrace Open Q&A /
avatar image
Question by Kohei S. · Jan 16 at 02:26 AM · Dynatrace Managed dynatrace saas
Why infrastructure baselines are defined only by static thresholds?
In Dynatrace, response time/error rates/loadings of services are monitored by dynamic and automatic baselines.
On the other hand, however, infrastructure monitoring is on the basis of not those baselines but pre-defined or user-defined static thresholds.
I wonder why Dynatrace doesn't use automatic baselines for infrastructure monitoring.
Are there any reasons for this?
Kohei
Comment
People who like this
0 Show 0
10 |2000 characters needed characters left characters exceeded
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
· Add your reply
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by Wolfgang B. · Jan 16 at 09:47 AM
Within Infrastructure metrics you can go with the 'automatic' mode as well but that does mean that Dynatrace decides on a good default threshold. You can overwrite the automatic mode by setting your own static thresholds.
You are right that we do automatically baseline all key performance metrics, error rate and traffic in a dimensional baseline cube (time to first byte, speed index, response time, visually complete, DOM interactive) as well as the service response time and error rates.
Within infrastructure metrics the automatic mode in many cases means to use the best practice standards that the individual vendors propose, such as thresholds introduced by AWS, VMWare, etc.
Comment
sebastian k.
Patrick H.
ROHIT S.
Kohei S.
Wai C.
5 Show 2 · Share
avatar image sebastian k. · Jan 16 at 09:59 AM 0
Share
thx for explanation :)
avatar image ROHIT S. · Jan 16 at 12:05 PM 0
Share
@Wolfgang B. Can we export the automatic configured threshold values(individual vendor proposed) for infrastructure being used in dynatrace ?
avatar image
Answer by Dave M. · Jan 16 at 08:45 PM
The static threshold technique is evolving with the new AI 2.0:
https://www.dynatrace.com/news/blog/enhanced-ai-ro...
Comment
Kohei S.
1 Show 2 · Share
avatar image Kohei S. · Jan 18 at 01:33 AM 0
Share
Hi Dave,
thanks for your information.
Exactly, 2nd generation AI makes better analysis!
Does this enable Dynatrace system to use automatically generated baseline for infrastructure monitoring?
avatar image Dave M. Kohei S. · Jan 18 at 03:41 AM 0
Share
From the blog above, it appears more that it looks at deviation from the norm. Similar to a baseline, but I believe a bit more flexible. This quote is key: "The example below shows how the new AI detects root causes without triggering false-positive alerts. The root-cause analysis states that the unhealthy host shows a 75% CPU usage increase as well as an increased number of Tomcat busy threads."
avatar image
Answer by sebastian k. · Jan 16 at 07:13 AM
According to my experience infrastracture metrics by default are using baselines and static thresholds as well... we’ve got reports from Dynatrace not only when static threshold were used but when change from pattern was to big as well. Why do you assume that there are only static thresholds?
Comment
0 Show 0 · Share
avatar image
Answer by Kohei S. · Jan 16 at 09:05 AM
Hi @sebastian k.
Oh, is that so?
The reason why I consider that infrastructure monitoring uses only static thresholds is the following URL.
https://www.dynatrace.com/support/help/shortlink/p...
This page seems to say that automated baseline can be used only for applications or services monitoring and infrastructure metrics aren't monitored with baselines.
Maybe, am I misunderstanding this description...?
Comment
0 Show 3 · Share
avatar image sebastian k. · Jan 16 at 09:08 AM 0
Share
Hmm I'm not sure but generaly situation like high CPU or low disk space is quite static. 95% of CPU usage isnt good the same like 2% of free storage. So such thresholds may be static. Maybe I've got notifications that were matching configured static thresholds and I've taken them as baselines violations. It's interesting
avatar image Wai C. · Jan 16 at 07:36 PM 1
Share
Hi Kohei,
Your understanding is exactly my understanding as well:
For service and application:
- 'Automatic' means baseline is used, we can configured how far off we are, from the baseline, before an alert is raised.
- 'Static' means use static threshold/SLA albeit baseline has been generated
For Infra
- No baseline is ever generated. Everything is static threshold, 'automatic' means use default threshold of the tool
- 'Static' means you use your own threshold.
So seems like the word 'automatic' carries different meaning (huge different) in the context of service and application, vs in the context of infra.
But again, this is my observation, I might be wrong, let's wait for some Dynatrace staff to chirp in.
avatar image Kohei S. Wai C. · Jan 18 at 12:37 AM 1
Share
Hi Wai,
thanks for your additional explanation!
Yes, what you mean is as well as my understanding.
'Automatic' in infrastructure thresholds means just like 'default thresholds Dynatrace suggests'
By the way, that reminds me that I posted a question about the meaning of 'Automatic' in the point of view of infrastructure monitoring.
The post is the following:
https://answers.dynatrace.com/questions/208354/what-does-automatically-in-the-view-of-anomaly-det.html
Your answer
Hint: You can notify a user about this post by typing @username
Up to 10 attachments (including images) can be used with a maximum of 52.4 MB each and 262.1 MB total.
Welcome to the
Dynatrace Community Forums
Check out the Forum User Guide and Forum Guidelines to learn how to get started.
Community Member of the Month
February 2019
Announcing Dynatrace's Community Member of the Month for February 2019, Larry R.! Click here to read more!
Employee Member of the Month
February 2019
Announcing Dynatrace's Employee Member of the Month for February 2019, Dave M.! Click here to read more!
Live webinar: AIOps done right through enhanced Dynatrace AI root cause detection
Learn the enhanced capabilities of the next generation Dynatrace AI root cause analysis and how to feed it with your own data sources.
Wednesday, February 20, 2019
Register today!
Register today!
NAM 2019 Beta is available
Would you like to have an early taste of what we have cooked up for 2019? We would love to hear your feedback and improve some of the new features. Check NAM 2019 Beta release notes.
Sign up today!
Follow this Question
Answers Answers and Comments
37 People are following this question.
avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image
Related Questions
Question about uninstallation of OneAgent Operator for Kubernetes 2 Answers
How much RAM is needed to analyze memory dump? 1 Answer
Is thier any possibilites to create a Custom alert on Log event monitoring 3 Answers
Confirmation of the status of oneagent service 2 Answers
Is there a limit on the length of SQL statements in Dynatrace Saas/Managed? 1 Answer
Forum Tags
java user management dotnet redis docker ios davis log analytics gui mobileapp database cloud foundry usability services faq management zones user sessions test automation Dynatrace Managed amazon web services plugins php android javascript processes monitoring nodejs sso rest api appmon license dynatrace saas mobile monitoring user tagging installation nam aix oneagent sdk purepath network synthetic monitors apache hosts iis user actions paas azure http monitor linux mongodb mysql dashboard tipstricks rest openshift mission control activegate webserver servicenow kubernetes rum host monitoring cmc key user actions notifications openstack technologies configuration account continuous delivery tagging postgresql security smartscape high five award agent documentation alerting auto-detection cassandra administration vmware oneagent
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
    • Synthetic Classic
    • BSM Open Q&A
