Can we Install Dynatrace Oneagent on Azure SQL server ?
rk00468487
Newcomer
If Oneagent cannot be installed , Do we have other monitoring patterns like APLI , SDK plugin , log monitoring for Azure SQL Server ?
3 REPLIES 3
skrystosik
SQL server can be monitored from application endpoint. This will give you insight about transactions performance, database statements, response time, failure rate etc. If you also need some host metrics that came from azure you can use integration:
https://www.dynatrace.com/support/help/cloud-platf...
Here you have informations about how to setup it. Azure (the same as AWS) will provide you bunch of metrics that can be used from infrastructure point of view.
There is no option for plugin execution and log monitoring. Actually logs can be pushed to Dynatrace via API but I don't think it is possible with Azure.
Regards, Sebastian
Hello ,
Many Many Thanks for the information :
Please tell if we can monitor following options with Dynatrace :
Metadata will be deployed on SQL Server in PaaS.
a. We will monitor database is up and running.
b. Listener is up and running
2. Storage Monitoring
a. ADLS Storage availability
b. ADLS Size monitoring
c. Blob Storage availability
Blob Size monitoring
Regards
See what entities you can monitor:
maybe this will be helpful for you:
https://www.dynatrace.com/support/help/cloud-platforms/azure/ - here is some additional info. Unfortunately I'm not familiar with Azure because non of my clients use it. I think the best would be documentation check. If you have any option for testing such integration do so. It does not consume extra licenses.
Regards, Sebastian
