question
Bastien T. avatar image
Bastien T. asked ·
How to link userSession with specific problems via API ?
I'm trying to link some userSession and userAction with specific problems via your API using USQL. I'd like to directly associate a specific and identified error with the number of users impacted by this one and to know how this error impacted users navigation. Currently, the number of users impacted by a specific error corresponds to the number of users connected at the same time the error triggered regardless of they had the error or not.
Do you have any solution ?
Thanks.
configurationmonitoringrest apiuser session monitoringdocumentationfaq
Bastien T. answered ·
Hi Sebastian,
Thanks for your quick reply ! If I understood correctly, that means i can't make the difference between a user who was affected by a specific error and another user that was not, if both of these users were connected when the error triggered ?
Bastien
2 comments Share
I've got the same problem on one of presentations for our clients. I was sure that affected users were those which really had issues. It find out that there were all users using application during some timeframe. Unfortunatelly we cannot go to user sessions for now from for example failed service calls so I think it might be hard to correlate this.
0 Likes 0 · ·
Ok, thank you very much. Your answers were helpful !
Bastien
0 Likes 0 · ·
Sebastian K. avatar image
Sebastian K. answered ·
I think it is working like you've mentioned before. For now amount of users does not exactly mean users that were affected, these users are potentially affected and you will not make anything alone with this. I've read sometimes ago about new problem detection algorithm in Dynatrace but I can't find source of this article to check if this will be changed in this update.
Share
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services custom event alerts notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions diagnostic tools session replay permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
