change slow operation threshold for only one URL
SB_12
Organizer
H, it is possible to change slow operation threshold of one particular URL instead of complete Software service?In my application there is one URL that is giving an operation time for 2 minute( this is normal for this URL). But Software service setting , slow operation threshold is set as 20 sec . So , all the hits on mentioned URL are considered to be slow operation. This is affecting the performance report of Application as a whole.
Is there any way to set slow operation threshold for one URL
Babar_Qayyum
Hello @swati b.
Currently, this is not possible because tweaking of slow operations threshold can be set globally or at the software service level.
Babar
