question
Tomoko F. avatar image
Tomoko F. asked ·
Can you do settings not to see on IIS module basis but on a method basis?
Hi,all
On the PurePath code level tab, you can see "aggregated IIS events" on a module basis.
I want to find out where it takes time in "aggregated IIS events".
Best regards,
Tomoko Fukuda
dynatrace saasiis
Dave M. avatar image
Dave M. answered ·
Would the Hotspots view help here? Go to Analyze tab and click the "View method hotspots" button. If there is a bottleneck in an IIS method, I assume it would be reported there.
2 comments Share
@Dave M.
Hi,Dave
Thanks for your information.
"Method hotspots" shows the number of executions.
Additionally, can you see somewhere that how long it takes for IIS method?
0 Likes 0 · ·
It actually shows the number of samples in which each method call was observed during CPU sampling. This points to the methods that are consuming CPU either by being executed for a long time, many times or some combination of the two. It does not provide actual timings, just an indication of where CPU cycles are being spent.
1 Like 1 · ·
Sebastian K. avatar image
Sebastian K. answered ·
As I remember for OneAgent and Appmon agent, IIS events are unsupported.
Share
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services custom event alerts notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions session replay diagnostic tools permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
