Can Dynatrace monitor Data Lake or Data Lake Analytics?
rk00468487
Newcomer
If No , can we use other options like API or SDK plugins .
Jakub_Mierzewsk
Inactive
Yes you can use API or SDK. We have OOTB support for Hadoop and Spark. Usually JMX plugins are easiest to build. Here are some helpful links.
https://www.dynatrace.com/support/help/extend-dyna...
https://www.dynatrace.com/support/help/dynatrace-a...
https://www.dynatrace.com/support/help/extend-dynatrace/oneagent-plugins/
