• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
        • Enterprise Synthetic Monitoring
      • Synthetic Classic
        • Synthetic Classic Open Q&A
  • Home /
  • Public Forums /
  • Dynatrace /
  • Dynatrace Open Q&A /
avatar image
Question by Jakub H. · Jan 21 at 01:06 PM · android
Dynatrace Xamarin Native Android Auto Instrumentation
Hi All,
I'd like to monitor my Native Android Xamarin app with Dynatrace OneAgent.
To auto-instrument my app I have tried the below (using Visual Studio)
1. Firstly, I have tried to auto-instrument by following this guide. Basically, all it tells (for native android) is to add Dynatrace.OneAgent.Xamarin nuget package and add Dynatrace.properties file in the assets folder. This has not worked, I did not see any data in the Dynatrace portal.
2. Secondly, I have tried the below after which I was able to see app data coming in Dynatrace portal - meaning the auto-instrumentation has worked. This is as per instructions on the dynatrace portal (instrumentation section)
  1. Download OneAgent for Android
  2. Created Dynatrace.properties file
  3. build and copy my apk file into the OneAgent folder
  4. call instrument.cmd apk=<AppName>.apk prop=Dynatrace.propertie
I was under impression that the nuget package automagically injects the mobile agent into my app (no source code modification required). Can someone who has successfully auto-instrumented a native android xamarin app tell me if there is anything else that needs to be done when using the nuget package?
Jakub
Comment
People who like this
0 Show 0
â–¼
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
Up to 10 attachments (including images) can be used with a maximum of 52.4 MB each and 262.1 MB total.
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Best Answer
Answer by Matthias H. · Jan 21 at 02:41 PM
Hello Jakub,
You are right usually this should work out of the box as we are adding the target automatically. It seems something didn't work as intended. As workaround you can add the Target snippet which is described in the documentation (https://www.nuget.org/packages/Dynatrace.OneAgent.... to your csproj file.
In the mean time I will try to find out why applying the target didn't work.
Comment
Jakub H.
1 Show 0 · Share
â–¼
avatar image
Answer by Jakub H. · Jan 21 at 03:19 PM
Hi Matthias,
Thanks for the suggestion, I can confirm that the workaround has worked.
Comment
0 Show 0 · Share
â–¼
Join the conversation!
First steps in the forum
Community User Guide
LIVE WEBINAR
"Power Demo: Software Intelligence for Cloud Infrastructure"
DECEMBER 12, 10:00 AM GMT / 2:00 PM ET
Register here
Live webinar: Ensuring Digital Business Availability with Dynatrace
Learn how Dynatrace Real User Monitoring automatically detects errors that impact your end users caused by erroneous 3rd party or CDNs.
December 10, 4:00 pm CET / 10:00 am ET
Register here
Register here
Register here
Follow this Question
Answers Answers and Comments
35 People are following this question.
avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image
Related Questions
How to set up user tagging in hybrid mobile app 2 Answers
Android Monitoring - Change max limit of user actions per session 2 Answers
Cannot see processes on host after installed OneAgent in IBM WebSphere Application Server which Dynatrace does support 2 Answers
Drill down to Purepath NOT available for Android App 1 Answer
Android Monitoring : User Session Timeout Configuration 4 Answers
Forum Tags
mobile monitoring dotnet iis chat kubernetes servicenow amazon web services mysql rest api cassandra dashboard oneagent sdk cmc application monitoring smartscape request attributes monitoring ui developer community user tagging log monitoring services ufo activegate auto-detection high five award webserver uem test automation license web performance monitoring ios migration management zones web services sso notifications host monitoring reports browser monitors java sap vmware maintenance window javascript appmon ai availability tipstricks automation extensions session replay permissions faq documentation problem detection http monitors easytravel network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration hosts user actions postgresql synthetic locations oneagent security Dynatrace Managed user management python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation database mission control apache mobileapp RUM php azure purepath davis plugins scripting aix nodejs android
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
    • Synthetic Classic
