Can I adjust sampling rate per key user action?
jason_dudley
Newcomer
For each user action I can adjust performance metric and anomaly detection. Is there an option to adjust sampling rate separately from the rest of the application? I'd like to set certain key actions to sample 100% all the time (cannot afford to do 100% sampling for whole site all the time).
nj_njoku
Inactive
Hi Jason,
Unfortunately this is not possible in the product presently. You can create an RFE for this feature in the Product Ideas forum here
NJ
