• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
        • Enterprise Synthetic Monitoring
      • Synthetic Classic
        • Synthetic Classic Open Q&A
  • Home /
  • Public Forums /
  • Dynatrace /
  • Dynatrace Open Q&A /
avatar image
Question by Wong S. · Jan 23 at 08:24 AM · configuration Dynatrace Managed activegate
Dynatrace Managed Cluster with custom domain name setup
I would like to verify on the Dynatrace Managed Cluster setup with custom domain name.
Hence, I read that in the forum that for such setup, we would need to register a FQDN with the DNS for the Dynatrace Managed Cluster. FQDN point to all the ip addresses of the Dynatrace Managed nodes.
Hope the above understanding is correct ?
Next, on the ActiveGates, do we need to do any additional configuration or it will contain require information once the Dynatrace Managed is properly setup with custom domain name and just need to install as per instruction provide on the Dynatrace Managed console.
Comment
People who like this
0 Show 0
â–¼
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
Up to 10 attachments (including images) can be used with a maximum of 52.4 MB each and 262.1 MB total.
1 Reply
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Best Answer
Answer by Radoslaw S. · Nov 19 at 08:27 PM
You are right. Just don't forget to opt-out from an automatic domain configuration. There are actually 2 different scenarios you can set up:
In case you want to use it as a Web UI domain and e-mail notifications:
  1. Set up a domain for all nodes' IPs.
  2. Configure the domain as:
    • Web UI URL (Settings -> Public endpoints)
In case you want to configure a domain for OneAgent communication:
1. Set up a domain for each node. E.g. node1.mydomain.com, node2.mydomain.com
2. Configure a domain at a given Node Details pages as "OneAgent communication address".
No other configuration is required.
Comment
0 Show 4 · Share
â–¼
avatar image Babar Q. · Nov 20 at 07:32 AM 0
Share
Hello @Radoslaw S.
I will also take this opportunity for my understanding as well.
We have default public endpoints for Dynatrace Web UI URL, but the ClusterActiveGates have a custom domain name with a public IP and valid SSL certificate.
Can we use the same for the public Dynatrace Web UI URL endpoints? IF YES
What will be the pre-requisites?
Babar
avatar image Radoslaw S. &. Babar Q. · Nov 20 at 08:43 AM 0
Share
If I get you right, you ask if you can setup a custom domain for Web UI URL? Yes. This is exactly what I wrote in my answer. Otherwise, please clarify.
avatar image Babar Q. Radoslaw S. ♦♦ · Nov 20 at 10:03 AM 0
Share
Hello @Radoslaw S.
Let me rephrase my question in the following way:
  1. Can we use the same custom URL for the Dynatrace Web UI URL which is used for the ClusterActiveGates? IF YES
  2. What will be the pre-requisites before changing the Dynatrace Web UI URL?
Babar
avatar image Radoslaw S. &. Babar Q. · Nov 20 at 11:52 AM 0
Share
How would it work at all? I can't imagine that.
Welcome to the
Dynatrace Community Forums
Check out the Community User Guide and First steps in the forum to learn how to get started.
Community Member of the Month
December 2019
Announcing Dynatrace's Community Member of the Month for December 2019, Enrico F.! Click here to read more!
Employee Member of the Month
December 2019
Announcing Dynatrace's Employee Member of the Month for December 2019, Silvia M.! Click here to read more!
Live webinar: Ensuring Digital Business Availability with Dynatrace
Learn how Dynatrace Real User Monitoring automatically detects errors that impact your end users caused by erroneous 3rd party or CDNs.
December 12, 4:00 pm CET / 10:00 am ET
Register here
Register here
Register here
Register here
Follow this Question
Answers Answers and Comments
32 People are following this question.
avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image
Related Questions
How does alerting on custom plugin metrics work? 1 Answer
Scenario 2: Pure Dynatrace Managed setup 1 Answer
Which cluster node (Dynatrace server instance without active gateway) will oneagent communicate directely with ? 2 Answers
How Long Does OneAgent takes to know if there is any new Active Gate added? 4 Answers
Public Security Gateway & Integrations 0 Answers
Forum Tags
mobile monitoring dotnet iis chat kubernetes servicenow amazon web services mysql rest api cassandra dashboard oneagent sdk cmc application monitoring smartscape request attributes monitoring ui developer community user tagging log monitoring services ufo activegate auto-detection high five award webserver uem test automation license web performance monitoring ios migration management zones web services sso notifications host monitoring reports browser monitors java sap vmware maintenance window javascript appmon ai availability tipstricks automation extensions session replay permissions faq documentation problem detection http monitors easytravel network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration hosts user actions postgresql synthetic locations oneagent security Dynatrace Managed user management python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation database mission control apache mobileapp RUM php azure purepath davis plugins scripting aix nodejs android
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
    • Synthetic Classic
