Dear All,
We have a situation where below java script is unable to instrument in the application's directory with the manual application or application detection rules even after defined JavaScript injection for all pages and providing JavaScript library location. (The application is without Web Server/or unsupported Web Server technology.)
But everything is working perfectly with the Default RUM application.
We want to use custom application instead of renaming the default detected application which is not recommended.
Babar
Answer by sebastian k. · Jan 23 at 10:27 AM
Did you checked advanced settings of default application? There is option for changing url where are sending data from ruxitagent and path from which agent is injected into the website. Be sure that you have proper settings for this in your custom application.
Hello @sebastian k.
Default application does not have any issues and for the default application (as per catch all rules) we don't need to configure advanced settings.
When I create a manual application for the same URL/Domain and set the JavaScript injection for all pages and provide JavaScript library location then the ruxitagentjs in not injecting in that directory and giving me a 404 error.
Babar
Hello @sebastian k.
Apologies I could not understand. If your point is to keep the default application with the rename instead of creating custom application then I would like to share that recently I heard that if we use the default application then on any new release of the application will change the name to the default application.
Babar
Babar I was on my mind to create new application rule without changing any advanced settings for a start. Check if this is working and than starting changes :)
Hello @sebastian k.
:) I started with the same mind but could not get any success, therefore, I asked in the community.
Babar
Babar you are totaly sure after all previous questions where we tweaked multiple settings that configuration is the same for both of them? Generally error you have means that somehow beacon url is unreachable for js ruxitagent script. Are you able to catch fiddler session for default and custom application according to this steps:
Hello @sebastian k.
Yes. I am pretty sure because I did every step with a care just to make it work but JavaScript is not injecting on the location.
Babar
And you are sure that all urls that are needed are in you new custom application? I mean that there is no option for having somehow double injection from 2 applications. I don't know if it possible but I didn't face such issue before :)
Hello @sebastian k.
Yes. I included the main URL and also the contained directory etc...
Babar
I think support may help, without direct access I don't have any more ideas :(
Learn the enhanced capabilities of the next generation Dynatrace AI root cause analysis and how to feed it with your own data sources.
Wednesday, February 20, 2019
Register today!
Register today!
Would you like to have an early taste of what we have cooked up for 2019? We would love to hear your feedback and improve some of the new features. Check NAM 2019 Beta release notes.
Sign up today!
