I have a monitoring requirement on Oracle Exadata Insights Data Warehouse. Does Dynatrace has API to monitor Oracle Exadata or what is the best option to monitor it?
rk00468487
Newcomer
9 REPLIES 9
Mike_L
Dynatrace Guru
Dynatrace Guru
Hi Rupinder,
We've looked into monitoring Oracle ExaData using an ActiveGate plugin. The challenge we ran into is the lack of an Oracle provided dev environment. If you're interested in getting help with building a plugin for ExaData and we're able to use your environment for the development and testing, reach out to your Dynatrace account manager.
Mike
Mike
Hi @Michael L. any update on this.
Avi
Hi @Mike_L did this lead to something after all?
Kind regards, Frans Stekelenburg                 Certified Dynatrace Associate | measure.works, Dynatrace Partner
So far no customer wanted it sufficiently to have us build it. @Julius_Loman had more luck though 😊
Mike
@Mike_L see my response here in another thread- https://community.dynatrace.com/t5/Extensions/Monitor-Oracle-exadata-using-Dynatrace/m-p/237327/high...
alvin_peterson
Frequent Guest
Curious if anything ever happened here... we also have a sizable ExaData environment we need to monitor. Looking for best approach.
~Alvin
Nothing came out of it so far. You can sign up for the preview of the Oracle insight program to get data from the Oracle database. However, to get statistics about the ExaData components it'd still be up to yourselves or a joint development effort.
Mike
Mike
torsten_granli
Visitor
Any updates on Exadata compatability Mike?
So far no customer wanted it enough to either pay for a custom solution or open up their environment for a joint solution.
Mike
Mike
