Execution time of queries inside stored procedues.
kamleshkaler9
Newcomer
Is it possible to find out the time spent within each query inside a stored procedure of SQL server ?
5 REPLIES 5
Julius_Loman
DynaMight Legend
DynaMight Legend
Definitely not with Dynatrace as it measures the response time from the application. If you call a stored procedure from your application, you can only measure the response time from the application point of view.
Jakub_Mierzewsk
Inactive
This will be delivered via Database insights for SQL on the roadmap for 2019
Hey Thanx and waiting for your roadmap to be executed . I want to know is it possible to achieve that standalone ? It's urgent and important ,if you can help .
I have been using database plugin , but I dont see any option that can give the details of queries running inside Stored procedures.
Can you please give the name of the plugin if it is released?
Thanks.
Hi @Jakub_Mierzewsk  is the plugin feature out yet ?
