I wanna setup an ActiveGate to bundle OneAgent connections but I don't know if I need more Host Unit.
Thanks a lot in advance
Answer by Ugochukwu N. ·
Hi Davide,
You do not need any host units for the Active Gate.
NJ
When is "Monitor Kubernetes workloads and cloud applications" expected to go GA?
Rationale/Reason of Not Able to Start Active Gate if License Expired?
SSL certificate management problem
Which license should we have when DB Monitoring with plugins?
Can you use more then one security gateway for the same environment?
