Does ActiveGate store data from OneAgent before forwarding to Dynatrace Server?
d_sarais
Guide
I would to know if ActiveGate usually store data before sending to Dynatrace Server and if data is uncrypted or protected in some way.
thanks a lot
3 REPLIES 3
Babar_Qayyum
Hello @davide s.
ActiveGate works as a proxy between Dynatrace OneAgent and Dynatrace Server.
ActiveGate collects messages from OneAgent instances and builds bulks, which are then sent in compressed form to Dynatrace Server. Network overhead can thereby be considerably reduced—a 70% reduction can be expected.
Dynatrace doesn't allow you to upload dumps to the Dynatrace cluster in the cloud. Instead you should set up an ActiveGate and configure it to serve as a host for memory dumps.
Babar
Thanks a lot for your quick reply! I got all these pro, but I would to know if these messages are temporarily stored into filesystem before the forward.
Thanks in advance!
They has to somehow because there alway can occure network problem and data should wait some time before expiration.
Regards, Sebastian
