Resolved! Custom Extension 2.0 sql query extension- Extension Signature is not valid 464 Views 4 replies 0 kudos databases extensions oracle
Resolved! Configuration-less Advanced SSL Certificate Check Plugin 44092 Views 86 replies 21 kudos data privacy and product security extensions knowledge sharing
Resolved! Monitoring state API for process groups (/api/v2/monitoringstate) 2278 Views 5 replies 14 kudos documentation dynatrace api
Stack trace not appearing in a front-end application 944 Views 3 replies 4 kudos application monitoring real user monitoring
sum(builtin:tech.generic.cpu.usage) versus builtin:host.cpu.usage or builtin:host.cpu.user 15 Views 0 replies 0 kudos cpu oneagent processes
How can I configure Dynatrace managed add-on for EKS? 2179 Views 7 replies 2 kudos aws dynatrace-operator kubernetes
Does the Extension Health Extension Count towards the ActiveGate Group limit 8 Views 0 replies 0 kudos activegate extensions
Resolved! How much does the new Databases App cost? 19 Views 1 replies 1 kudos databases latest dynatrace
