Port opening for Active gate in Dynatrace SaaS
sangeetha_mitta
Organizer
Could you please clarify on the below? (dummy ip address are mentioned below)
Active gate VM Has 3
IPs.
IP in VLAN -123.11.11.23
IP Patio - 342.144.145.37
Public IP address in DMZ - 222.218.27.88
we have raised
firewall port from source 123.11.11.23(IP IN VLAN) to SAAS tenant with 8443 port.
Is this
correct or do we need to select source IP as 222.218.27.88(public IP in DMZ) instead
172.21.14.73.
Thanks&Regards
Sangeetha
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
If you run multiple NICs define the communication NIC by defining that in config.properties file. Set bindToNetworkInterface property under section [connectivity]
Then restart AG.
Senior Product Manager,
Dynatrace Managed expert
ChadTurner
DynaMight Legend
DynaMight Legend
Review the following document as what ports need to be open depending on your use case: https://www.dynatrace.com/support/help/setup-and-configuration/dynatrace-activegate/configuration/wh...
-Chad
