question
Sathwika V. avatar image
Sathwika V. asked ·
What is difference between Response time Vs total process time in Dynatrace managed ?
In Pure paths i noticed response time and total process time. In some cases i noticed different numbers.
What is difference between response time and total process time ?
Sathwika
configurationDynatrace Managedadministrationdocumentationuser management
Christoph N. avatar image
Christoph N. answered ·
This stems from asynchronity. A request can have async execution flows, possibly in parallel, possibly still running after response has already been sent. The time of async execution flows is added to the total processing time, but not to the response time.
1 comment Share
Thanks for reply!!
Your answer is helpful.
0 Likes 0 · ·
Gary S. avatar image
Gary S. answered ·
Is there a way to make the response time be the total processing time, or be able to view the total processing time when doing graphs, etc?
Share
