Can Oneagent provides connectivity Percentage of properly established TCP connections
mayuresh_athava
Participant
mayuresh_athava
Participant
Also want to know does it compare to TCP connections that were refused or timed out
Babar_Qayyum
Hello @Mayuresh A.
Connectivity shows the percentage of properly established TCP connections compared to TCP connections that were refused or timed out. It shows when services were available to clients and when they were not, over time.
Have a look in the below link for more insight.
https://www.dynatrace.com/support/help/monitor/net...
Babar
