writing BT in Dynatrace managed
ramakrishnan_p-
Organizer
i have a requirement
user clicks a button in the page. how can we write the same in the Dynatrace managed?
PFA screenshots. which is written in Appmon. i wanted to replicate the same scenario in Dynatrace managed. Adding2 filters with AND condition.
6 REPLIES 6
ramakrishnan_p-
Organizer
bt-jan31.jpguser-action.jpg forgot to attach the files
pahofmann
If you want to see all user sessions, that have those specific user actions in them you can use multiple user action name filters in the user session view:
If you want to use it regurarly without having to reenter the filter every time you can just bookmark the page after setting the filters, they are included in the URL.
Dynatrace Certified Master, AppMon Certified Master - Dynatrace Partner - 360Performance.net
Hello Patrick
thanks for your reply. another question. can we mark this in our Dashboard? [ pin dashboard] so that i can monitor easily. also i wanted to know how to put condition whether a Button is available or not?
thanks
RamP
You can pin that graph to a dashboard unfortunately. You could mark the button click as a key user action and create a custom chart for that though.
AlexanderSommer
Dynatrace Champion
Dynatrace Champion
You can also use the user session rest API to define a query: https://www.dynatrace.com/support/help/monitor/use...
At this point in time you only can use the USQL with the Rest API, but in a few weeks, you can use it also within the new advanced user session query UI.
ramakrishnan_p-
Organizer
Hello Patrick
thanks
RamP
