we have a known error which comes under 4xx.
is it possible to suppress the 4xx error in Dynatrace Managed? if yest how.
we wanted to suppress the entry = /commerce/abc/xyz/type under 404
Answer by Ugochukwu N. ·
You can modify the error detection rules ignore HTTP response codes or exceptions that would normally indicate an error but this is done on a Service level not on an individual request level. See more on this here
Hope This Helps
NJ
