Process group detection rules based on environment variables
d_sarais
Guide
Hi all! Have you ever set an environment variable to use it in custom process group detection rules?
We have servers that restarts every day and I can't find a solution to set a permanent environment variable on Linux.
Thanks a lot in advance
skrystosik
as I understand, you are adding environment variable in OS and after restart it dissapear? I'm using this option in daily environment configurations. It is working fine.
I think here is proper solution:
https://unix.stackexchange.com/questions/21598/how...
Generally you can alway try to find solution for you os version and distribution. You need permanent solution, not session one 🙂
Regards, Sebastian
Julius_Loman
DynaMight Legend
DynaMight Legend
This really depends on how your services are started (shell script, systemd unit file, sysv init script). The best method is to set (export) the variable in the startup script/systemd unit file itself and not setting up the user or system shell profile.
