Script Output on Dynatrace
amarpreet_sawhn
Contributor
I have a script which is executed on the DB and the output is exported to an excel file and then gets emailed to us. Is there a way to send teh output of that script directly to Dynatrace managed. Like creating a dashboard and it outputs the results on a tile.
Amarpreet
skrystosik
Hello, you have to send it to dynatrace as custom measures (not xls file, you have to prepare proper json payload and send it over API).
https://www.dynatrace.com/support/help/dynatrace-a...
Then you should be able to chart them.
Regards, Sebastian
