How to disable AWS Monitoring without deleting settings
Hi all,
I have a question.
Is there a way to disable AWS Monitoring without deleting Settings(ex. Access Key ID/Secret access key) ? I checked documents, but I could not find it. There is no way to do that?
4 REPLIES 4
skrystosik
On dynatrace side I don't know the way but maybe somwhere in AWS you can change permissions for credential to block them temporary?
Regards, Sebastian
Hi Sebastian,
Thank you for your reply.
Your information is very helpful !
Thank you again.
michal_nalezin
Dynatrace Advisor
Dynatrace Advisor
You could also use tags to limit the scope of AWS monitoring.
Hi @Michal N. ,
Thank you for your comment ! Your information is very helpful !
