question
IGOR M. avatar image
IGOR M. asked ·
How nginx and IIS .NET instrumented
Hello
Can one point me into docs or tell how is nginx and IIS .NET instrumented by OneAgent?
Customer ask exact info.
Is it added libraries or API like JMX used?
Thanks!
Igor
oneagentauto-detectiondotnetiis
1 Answer
Julius L. avatar image
Julius L. answered ·
Actually, the oneagent library is added to the process. This library handles the instrumentation for every process. Depending on the process type, it links also other library (for example liboneagentnginx ).
Generally, each library intercepts necessary calls inside the instrumented process. For NGINX it intercepts calls to NGINX functions. For NET it also inserts oneagent NET assemblies. ( you can find them in the oneagent directory).
5 comments Share
Thank you Julius! Is it documented somewhere?
0 Likes 0 · ·
Unfortunately, I don't think this is publicly documented.
0 Likes 0 · ·
Cust demands official description to let us install oneagent on servers. And there is no test env. Hopefuly these servers in balancing ferm.
0 Likes 0 · ·
If you need official technical details, the best approach would be to contact Dynatrace product managers or your sales representative to obtain them.
0 Likes 0 · ·
Clear. How to reach them promptly and directly?
Thanks!
0 Likes 0 · ·
