Conversion goal tile showing different numbers than conversion goal charts
rohit_sharma
Guide
I have observed the tile we have used for conversion goals shows different conversion % than that in the infographic shown in UEM. Is there any difference in calculation of conversion goal rates in both views ? Or is it the dashboards have some lag ?
skrystosik
Are you sure that timeframe and scope of application is the same in both examples? In application when you are looking at data sometimes you can see that for example analysis is on 15 minutes timeframe. On dashboard you can have wider scope 🙂
Regards, Sebastian
I can see the analysis for every 5 min on infographic and time window selection is 1 hour for both, but I still see differences in % values of conversion goals.
