How to push ServiceNow Data from SNOW API to Dynatrace to Map Problems detected in Dynatrace co-relate with Incidents created. Any ideas about this?
annep8326
Newcomer
skrystosik
I’m not sure what you want to do. I dont’t think it is possible to do anything except pushing comment to problem with incident url in service now.
https://www.dynatrace.com/support/help/dynatrace-api/environment/problems-api/comments-to-a-problem-...
But if you integrate snow with Dynatrace via webhook you should be able to match problems with incidents on service now side.
Regards, Sebastian
