I could not start the Dynatrace associate exam due to connectivity, missed the exam?
wagner_souza
Inactive
I was unable to start the Dynatrace associate exam because of connectivity, did I miss the exam? What should I do? Will I have to pay another $ 200 exam?
3 REPLIES 3
rastislav_danis
DynaMight Pro
DynaMight Pro
probably yes, but have you contacted University team ?
Alanata a.s.
wagner_souza
Inactive
i'm open ticket.
skrystosik
As said Rastislav, contact with university. In general you should check technical requirements (there is tool for that) before exam. Option to start again is mostly when you loose connection during exam. You should contact them on phone or via chat and point your issues. If it is their fault maybe you will be able to get new schedule but you should contact them and explain situation.
Regards, Sebastian
