Can I select multiple Slack channels under problem notification to send same alerts for different channels.?
moin_ghori
Participant
moin_ghori
Participant
Here is the problem
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
No that's not possible, but there is an easy workaround by creating a second Slack integration with the same AlertingProfile filter.
