Active gate server processes and services
sangeetha_mitta
Organizer
Hi
What are all the processes ad services that run in Activegate server (Dynatrace SaaS)?
Could you please help us with the above information
Thanks&Regards
Sangeetha
Julius_Loman
DynaMight Legend
DynaMight Legend
Typically it has two or more processes, depending on the configuration:
  • Gateway itself (has com.compuware.apm.collector.core.CollectorImpl in the process arguments) - there can be more than one instance of
  • Gateway autoupdater ( autoupdater.sh ), runs as root
  • Remote plugin module, ( remotepluginmodule in the process arguments ), if you use remote plugins.
Thank you Julius
