question
Nahuel B. avatar image
Nahuel B. asked ·
Extract of hosts - max 3 days.
I'm trying to extract data of all host, in order to get EntityId, and some other values, to use API to post some data.
But i'm only get info for host up to 72hours.
If I change "startTimestamp" to begining of December 2018, following line appears:
"The selected timeframe exceeds the allowed limit of 3 days."
- Do you know if there is a way to extract all data of host, and not only the last 72hs monitored asset?
Thanks a lot.
rest apihost monitoring
1 Answer
Radoslaw S. avatar image
Radoslaw S. answered ·
That is not possible by one query - as that would expose a vulnerability to overload Dynatrace service when extracting large portion of data.
See this topic as a workaround: https://answers.dynatrace.com/spaces/483/dynatrace-product-ideas/idea/199493/rfe-extending-the-inactive-status-of-services-to-a.html
You simply have to use the startTimestamp and endTimestamp to select a historic timeframe and you will get all entities and relationships that were active and seen at that point of time.
You only have to make sure that between start and endTimeframe there is not more than 3 days to not explode the result set.
Share
Space Topics
mobile monitoring dotnet synthetic monitoring reports iis chat kubernetes servicenow amazon web services mysql mainframe rest api errors cassandra dashboard oneagent sdk cmc application monitoring openkit smartscape request attributes monitoring developer community user tagging log monitoring services ufo syntheticadvisory activegate ip addresses auto-detection high five award oracle hyperion webserver uem usql iib test automation license web performance monitoring ios news migration management zones index ibm mq web services custom event alerts notifications sso host monitoring knowledge sharing reports browser monitors java hybris sap vmware maintenance window user action naming javascript appmon ai synthetic classic availability tipstricks automation extensions session replay diagnostic tools permissions davis assistant faq documentation problem detection http monitors server easytravel apdex aws-quickstart network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration user actions postgresql synthetic locations oneagent security Dynatrace Managed user management custom python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation masking error reporting database mission control jmeter recorder apache mobileapp RUM php threshold azure purepath davis scripting agent aix nodejs android
