Co-relation of configuration ID using one agent
Today we
have users requesting for statistics of usage about the configuration (number of
users per application), and they are asking if it is possible to
also get the country of origin of the users.
But the
issue is that on configuration side, we are too far down the network(many layers above us) to
get the user’s location, and we are searching for a solution to get this
information from other layers and/or monitoring tools already in use
One of the
idea is to track the configuration session ID(as shown in screenshot) , which is unique per configuration session, and link to it the
user location.
Is it possible to identify the configuration session ID and co-relate it using one agent?
pahofmann
Is the application injected with Real User Monitoring? Then you should get metrics like number of user session per country out of the box.
If you want to correlate it to a session ID, it is not yet possible, but will be with the upcoming EAP for User Session Properties and User Action Properties.
Dynatrace Certified Master, AppMon Certified Master - Dynatrace Partner - 360Performance.net
