Problem user session
felipe_oliveira
Participant
In the client application Google Analytic shows that they are with 106 users online, and Dyna is showing only 30 users. Do I have to do any configuration to capture the sessions in dynatrace?
pahofmann
By default Real User Monitoring is configured to capture every session of the application, although you can set a sampling rate in the application setting. Weather Do-Not-Track headers are honored by the monitoring tool or can also have an impact on the number of active users.
Another thing is the session timeout. Depending on whats configured in google analytics for when a session is considered as ended, you will get different results for current active users.
Dynatrace Certified Master, AppMon Certified Master - Dynatrace Partner - 360Performance.net
