About difference of available timeseriesId between Dynatrace SaaS and Managed
kohei-saito
Helper
are there 'timeseriesId' metrics for TimeseriesAPI available on only one of either Dynatrace SaaS or Dynatrace Managed?
For example, I can use "com.dynatrace.builtin:appmethod.useractioncount.load" for Dynatrace Managed Timeseries API, but cannot for SaaS.
With this metric, I got the 404 response from SaaS Server:
"error": {
"code": 404,
"message": "Timeseries id com.dynatrace.builtin:appmethod.useractioncount.load is not valid"
c.f.)
If you look at this page(https://www.dynatrace.com/support/help/shortlink/a...), you will find this metric on Managed but not on SaaS.
Kohei Saito
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
That one is easy to explain, Dynatrace SaaS release cycle is 2 releases (~4weeks) ahead of Dynatrace Managed. That is the reason why in some cases an id can be already available in Dynatrace SaaS while it will be available 4 weeks later in Dynatrace Managed. Dynatrace SaaS and Dynatrace Managed are identical from codebase and feature set, its just because of the release cycle.
Best greetings,
Wolfgang
I see, that makes sense.
Dynatrace Managed is released in advance of SaaS, so some of available metrics in Managed may not be available in SaaS.
Thank you very much!
Kohei
