05 Mar 2019 10:06 AM
Hello, i have just installed the latest version of "Performance Signature with Dynatrace for Jenkins" (https://github.com/T-Systems-MMS/perfsig-jenkins)
on my Jenkins server. Unfortunately, I can not add a new Dynatrace API token. Is this problem known to you and is there a solution?
07 Mar 2019 08:51 AM
A workaround is to create the Dynatrace API Token in the Jenkins credentials setting. It then is available to choose when configuring the Dynatrace Server.
I also ran into this issue a few times, a fix would be great.
02 May 2019 03:34 PM
This is a known bug in the Credentials Plugin: https://issues.jenkins-ci.org/browse/JENKINS-42546
One workaround is to save the global settings and use the add credentials button afterwards.
