Execution plans for SQL DB
juan_antonio_co
Participant
How can I see the execution plan for a SQL server with OneAgent deployed?
david_n
Inactive
Hello Juan,
To view the execution plan metrics you will have to go to databases -> select your MS SQL server and click SQL details and Further details tabs to gather the information you need.
Here is a link that explains more. Take a look at the compilations, recompilations and process block metrics: https://www.dynatrace.com/support/help/technology-support/monitoring-support/mssql/
David Nicholls
