• Forums
    • Public Forums
      • Community Connect
      • Dynatrace
        • Dynatrace Open Q&A
        • AppMon & UEM Open Q&A
        • NAM Open Q&A
        • Enterprise Synthetic Monitoring
      • Synthetic Classic
        • Synthetic Classic Open Q&A
  • Home /
  • Public Forums /
  • Dynatrace /
  • Dynatrace Open Q&A /
avatar image
Question by Said A. · Mar 11 at 03:24 AM · RUM
Is it possible to get more information on why 3rd party script failed?
Hi all,
New Dynatrace user here, we are just trying to figure out an interesting issue,
Time to time Dynatrace (SaaS) will raise "problem" alert due to increase rate of JavaScript errors in RUM (Real User Monitoring) part of the application.
For most of the cases we are able to see which script caused the issue and what's the error message, then we can take action and fix it.
However there are rare cases where only thing we can see is "Script error". (screenshot #1)
We can see that it's 3rd party but it's still concerning since any JS can break the page looks or the flow, especially our 3rd party A/B testing or ads scripts.
When we drill down to above item, below is what we get. (screenshot #2)
"Script file information not available due to security constraints enforced by the browser for JavaScript from 3rd party domains."
Problem is, when I visit the same page with different browsers, I cannot reproduce any 3rd party JS errors. There is an ad script which is causing CORB error on the page but I'm not sure if that's all there is to it. Maybe there was indeed a JS error on the page, not just CORB. (Scripts introduced by GTM are dynamic, can be added/removed/modified via development or deployment.)
Even if it's CORS/CORB error, it would be good to know if there is a way to see which script's request (XHR or fetch) caused the issue for requesting which resource. I can see the CORB error right now but last time I checked, it wasn't there.
I'm wondering if there is a way to work around this and get the necessary info or whether this is something which can be added as an enhancement to the Dynatrace platform.
Comment
Myrvin Y.
James T.
People who like this
2 Show 0
â–¼
  • Viewable by all users
  • Viewable by moderators
  • Advanced visibility
Up to 10 attachments (including images) can be used with a maximum of 52.4 MB each and 262.1 MB total.
  • Sort:
  • Most voted
  • Newest
  • Oldest
avatar image
Answer by James T. · Oct 28 at 07:15 AM
Sorry for reviving this, but I'm facing the same issue. There seems to be no way to analyze a 3rd party script failure. Checking the console output in the affected page, it seems to be an issue with ads but not sure.
I also don't quite understand Sebastian's solution to use Fiddler
Comment
0 Show 0 · Share
â–¼
avatar image
Answer by Sebastian K. · May 10 at 06:43 AM
When you go down on this script, you should see button "Upload minified file". You can download script by your own, upload it to DT and you should be able to see place in code which makes issues.
Comment
0 Show 0 · Share
â–¼
avatar image
Answer by Said A. · May 10 at 01:57 AM
Thank you for your answer @sebastian k.
I'm still looking for a way to see the error details for real users.
I have a feeling there are device/browser combinations out there - which we are not "QA"ing with - encountering these issues.
Comment
0 Show 0 · Share
â–¼
avatar image
Answer by Sebastian K. · Mar 11 at 08:22 AM
If dynatrace is not able to show you this I recommend you to use fiddler pared with your mobile device. You will be able to see error details:
https://docs.telerik.com/fiddler/Configure-Fiddler...
Comment
0 Show 0 · Share
â–¼
Welcome to the
Dynatrace Community Forums
Check out the Community User Guide and First steps in the forum to learn how to get started.
Community Member of the Month
December 2019
Announcing Dynatrace's Community Member of the Month for December 2019, Enrico F.! Click here to read more!
Employee Member of the Month
December 2019
Announcing Dynatrace's Employee Member of the Month for December 2019, Silvia M.! Click here to read more!
Live webinar: Ensuring Digital Business Availability with Dynatrace
Learn how Dynatrace Real User Monitoring automatically detects errors that impact your end users caused by erroneous 3rd party or CDNs.
December 12, 4:00 pm CET / 10:00 am ET
Register here
Register here
Register here
Register here
Follow this Question
Answers Answers and Comments
34 People are following this question.
avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image avatar image
Related Questions
What is the use of Web Checks In Saas...? 1 Answer
Can i use third party content count(avg) measure to create incident based on a threshold of avg number of third party content on a visit or user action? 1 Answer
The relationship between DEM and Oneagent 1 Answer
Alerting/charting of javascript errors 0 Answers
Why I don't see RUM data? 2 Answers
Forum Tags
mobile monitoring dotnet iis chat kubernetes servicenow amazon web services mysql rest api cassandra dashboard oneagent sdk cmc application monitoring smartscape request attributes monitoring ui developer community user tagging log monitoring services ufo activegate auto-detection high five award webserver uem test automation license web performance monitoring ios migration management zones web services sso notifications host monitoring reports browser monitors java sap vmware maintenance window javascript appmon ai availability tipstricks automation extensions session replay permissions faq documentation problem detection http monitors easytravel network docker tags and metadata cloud foundry google cloud platform synthetic monitoring process groups account usability dynatrace saas gui paas openshift key user actions administration hosts user actions postgresql synthetic locations oneagent security Dynatrace Managed user management python technologies mongodb openstack user session monitoring continuous delivery citrix configuration alerting NGINX action naming linux nam installation database mission control apache mobileapp RUM php azure purepath davis plugins scripting aix nodejs android
  • Forums
  • Public Forums
    • Community Connect
    • Dynatrace
      • NAM Open Q&A
    • Synthetic Classic
