custom integration, test notification: to fill payload values
Hennadiy_Zolota
Newcomer
Hello.
Is there a way to set different values when sending test notification of custom integration?
I mean: how to fill payload values like
{'ProblemTitle':'{ProblemTitle}','ProblemID':'{ProblemID}','PID':'{PID}','ProblemSeverity':'{ProblemSeverity}','ImpactedEntity':'{ImpactedEntity}}','ProblemURL':'{ProblemURL}','dt_severity':'{State}','dt_Tags':'{Tags}'}"}
with test info I need so it will be sent like
{'ProblemTitle':'footitle','ProblemID':'123','PID':'0000000000000000000_0000000000000V2','ProblemSeverity':'severityineedto send','dt_Tags':'tags_array_to_send'}"}
skrystosik
There is no such option but if it is possible for you you can alway try sending such paylos with POSTMAN or other tool for API testing.
Regards, Sebastian
