How to set 350ms as threshold for services in anomaly detection?
sarathkumar_ra1
Newcomer
How to set 350ms as a threshold for services (globally) in anomaly detection (Dynatrace managed version)?
Joe_Hoffman
Dynatrace Leader
Dynatrace Leader
I'm curious as to the usecase where you find it logical to set the same threshold for all services? Normally services are different and need different baselines, that's the idea behind Dynatrace auto defining the baseline.
Did you look in Settings -> Anomaly Detection -> Services?
sarathkumar_ra1
Newcomer
You can look in Settings -> Anomaly Detection -> Services, there are multiple numbers will be given. From there I need an exact value to set threshold as 350ms to define the baseline threshold value.
