Is possible to create custom chart with mobile app's user action?
d_sarais
Guide
Hi guys,
I would to pin to dashboard a user action from iOS native app but seems that is not possible.
Any workaround for this?
Thanks a lot in advance
nj_njoku
Inactive
Hi Davide,
Unfortunately, you cannot add a chart for a metric on a specific mobile action in a custom chart presently. There are plans in the near future to implement the key user action feature for Web RUM in Mobile and you would be able to do this then.
NJ
Ahhh! very bad thing! Thanks Ugochukwu for confirmation
