when are session properties being updated
gilgi
DynaMight Champion
DynaMight Champion
Hi All,
Trying to figure out session properties mechanism for the following example scenario (as was demonstrated on the business dashboarding webinar). Assume you have an ecommerce website and you wish to use the user session query to display how much revenue is at stake per APDEX category.
The basket amount can be either retrieved from the server side return value of a function or from the web ui by using a css selector on the field displaying the basket amount (it is displayed at all times and not only on checkout).
My question is how does session properties being evaluated and updated ? are they only set the first time it sees a value or is it continuous ?
How would you implement such usage ?
Gil.
skrystosik
I think it will work the same as user tag which is caught as soon as it is detected and after this it is updated when new value is found.
Regards, Sebastian
So, the captured properties are not appended? For example, a real user makes orders, and in the same session, we could have multiple order IDs. I would like to capture the OrderID as a javascript variable, and add the orderID metadata to the session.
Only the last orderID will be shown? Is it possible to be appended to the already captured OrderIDs?
Thank you,
Dimitris
