Report source code of dynatrace wrap application.
I have questions.The Dynatrace has a report confirming that the source code used wrap application has no vulnerabilities.
Thank you
3 REPLIES 3
matthias_hochri
Dynatrace Pro
Dynatrace Pro
Hi, can you try to elaborate the question a bit? I sadly don't understand it. What is a warp application?
Hi Matthias H,
Instrument application
Thank you.
Thomas_Wirth1
Dynatrace Champion
Dynatrace Champion
Hey @dynatrace A.,
if you want to receive more information about the security details of the product then you should create a support ticket. To help the support team handle your request, you should be more specific about the components and the information you are interested in.
Based on your screenshot I assume that you are interested in the components "OneAgent for Android" and "Android auto-instrumentor" and based on your comments I assume that you want to receive a vulnerability report.
