Red color shown in Africa, in the apdex-worldmap tiles, but after click into it there is nothing in Africa.
waikeat_chan
DynaMight Pro
DynaMight Pro
Anyone has any idea? or has face this before?
Before clicking:
After clicking:
Best Regards,
Wai Keat
7 REPLIES 7
waikeat_chan
DynaMight Pro
DynaMight Pro
Also, in user session there, I didn't see any session from Africa Continent, only got user session from Asia Continent and also Europe Continent.
Can you please create a support ticket for this?
Joe_Hoffman
Dynatrace Leader
Dynatrace Leader
I see your problem, in South America. Also there appears to be lots of green in South Asia that does not show up on the WorldMap Tile. So the inconsistency seems to be for many countries. I suggest you open a support ticket, or use the in product chat feature and have someone from the support team investigate.
KlausEnzenhofer
Dynatrace Champion
Dynatrace Champion
What are the time frames you are using? The main difference between the tile and the big world map is that the tile leverages time series data and the big world map does on demand analysis. Depending on the time frame you have selected there can be slight differences and for regions where you only have a view clicks this can cause those differences.
Hi Klaus,
I am using last '24 hours'
Isn't the World Map tile only "live data" ?
franz_soengen
Inactive
Hi @Wai Keat C.,
I see that France is red on your world map. Could that simply be French Guiana being displayed as part of France in one of the maps?
best regards
Franz
