Problems Flagged Out in 'Applications' Dashboard but not in Problem Dashboard
waikeat_chan
DynaMight Pro
DynaMight Pro
In the applications, I did see there is this event of user action degradation highlighted (the user browser there is also highlighted in red color).
But I wonder why no problems tiles is raised?
wolfgang_beer
Dynatrace Leader
Dynatrace Leader
Did you check on the same application within the problems tile above if it shows a 'Frequent issue'?
https://www.dynatrace.com/support/help/how-to-use-dynatrace/problems/problem-detection/detection-of-...
Hi Wolfgang,
I did check on the problems/event of this application itself, there is indeed a lot of 'user action duration degradation' event.
But the combination of 'XHR and Chrome 72' is not a frequent issue.
Best Regards,
Wai Keat
