Alert on user sessions drop anomaly
imoskovko1
Inactive
Hello Gents!
I am not sure how to catch sudden user sessions drop anomaly.
In [Settings -> Anomaly detection -> Applications]
or in [Applications -> App Name -> Settings
General]
i cant find any option.
Can one suggest please. Thanks!
Igor
5 REPLIES 5
JamesKitson
Dynatrace Guru
Dynatrace Guru
In the application settings under anomaly detection. You can set that for all apps or specific ones:
imoskovko1
Inactive
Hello James!
Thank you for help. I have found this app traffic anomaly detection and changed it from default %50 to %20. Waiting for results.
But we are looking for number of sessions drop alert. Do you think it is worth submitting enhansement request?
We had 2 hours leased line outage and only click path synthetic monitor noticed it. All else was green in Dynatrace. So we are thinking about tracking user sessions to our app.
Igor
imoskovko1
Inactive
Actualy 1 hour of net problems:
david_n
Inactive
Hello Igor,
The traffic drop anomaly detection rule will catch scenarios like that. With no sessions, your user sessions and app traffic will also drop and cause the problem notification to be created. Please note that it takes a week for the AI to learn the normal traffic for each day before it starts to throw these alerts. So you will need to give it time.
David Nicholls
imoskovko1
Inactive
Thank you David! I am trying it curently
